FactoryTalk View ME-Symbol Factory Selector Switch.Can you visually make that toggle?
Rob S.
Sep 2008
Maryland
739
Good Morning ,
I'm working on a FactoryTalk View ME project , and I'm using , out of the Symbol Factory , ( in the 3D Pushbutton group ) a Selector Switch . I guess you can make that visually toggle , I guess ?
If so , how do you actually do this ?
Thanks so much ,
Rob,
One way is to copy the two (2) Symbol Factory selector switches types you would like to display then place on top of each other and use Animation expression for Visibility for the controlling tag for each switch type.
Good morning Rob. Depends on whether you want this to be an indicator only or control with indicator. Also, is this a two or 3 position switch.
My suggestion is, based on the criteria above, you'd create a multistate indicator and insert the bitmap of your choice from Symbol Factory into the image for each state.
If you want this to control also, add a transparent button object below the indicator. I did something like this a long time ago in ME for an illuminated pushbutton that showed the button depressed/released image when lit/extinguished (4-states). The indicator used an expression that looked at the status of the button and indicator tags in order to determine state 0-3.
Hope this helps.
Ok. So really this Selector Switch is only a image , right ? So I would need to
put a pushbutton , with a tag attached , under this Selector Switch , correct ?
Correct. If you only need two states like a regular illuminated PB, you might be able to do this in a single object. If you have a momentary PB input, you'd use a separate indicator tag. Haven't tried that before. o_O
Have a read here if you've access?...
1083556 - FactoryTalk View ME: Creating an HOA Push Button
Access Level: TechConnect
Regards
George
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
129
Hello all, I was modifying an HMI in factory talk and went to change a go to display button using the ... to select from a list as I had done...
168
Hello, We recently upgraded our control server to a newer model. After the transition we are experiencing issues with our trend graphs to where...
120
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
200
This is admittedly a pretty obscure problem, but maybe someone else has run into it, or at least something similar. For reasons I won't get into...
132
