Large Display Screens (TV) - Scrolling data
I'd add another vote for the Redlion PTV, but if the budget is tight I'm fairly sure AdvancedHMI will run on a Raspberry PI. https://www.youtube.com/watch?v=DhkBVPBgBD0
Normally I wouldn't reccommend Raspberry PI for an industrial environment, but it looks like a company called Kunbus has "industrialised" it and also produces a range of gateway modules for most of the industrial protocols.
https://revolution.kunbus.com/revpi-core/
EICS
to answer your question yes I have used them many times I keep the link in go to list for materials.
If you don't see what you want call them they have a very good support team.
They have different types of communications available for them
Looking for suggestions for a large screen display (greater than 37in) with wifi that will boot directly to a web browser, then point to the same...
25
7,902
Needing a panel mount style timer that would interface with a large numerical display. Tankline with 20000 + gallon dip tanks. Operators lower...
1,898
We have many alarms in our plant that get routed back to our maintenance shop. Most of this could be communicated over Ethernet from various...
3,657
Ok What am I looking for ? A plant I visit has an ancient chart recorder, connected to a pc running some old Dos software, which simply...
2,944
This is a picture of a 60" LED TV running Windows 8.1 from a $129 PC. It has a 1.33Ghz quad core processor with 2Gb RAM, so it's not an extreme...
17
7,134
