Display Data suggestions on large monitor
Pablox
Oct 2010
Home
72
Ok
What am I looking for ?
A plant I visit has an ancient chart recorder, connected to a pc running some old Dos software, which simply displays the data from say 16 inputs on 16 rectangles on a large pc monitor.
There is no automation ,logging the data is not used but the operators need to see the constantly updating data in front of them.
All works fine for years, but it's now obsolete and some day it won't work.
As an upgrade, I would like to get a "unit" which would take a mixture of k type thermocouples and 4 -20 ma inputs (say approx. 30 inputs in total), with data logging option preferable.
Most importantly, I need a means of configuring/displaying the "points" on a large screen, which simply updates every 10 seconds.
Any suggestions for hardware which will suffice.
Do you want to run the thermocouples and analog values into a PLC to collect the data then display the PLC data on a large screen? Or are you looking to feed the signals into something that can directly display the values such as a chart recorder does?
Hi m8,
A device that directly displays the values like a chart recorder, would be fine.
Problem is I haven't seen a unit, which I can configure to display clearly legible values on a decent sized screen/monitor, so something like a chartless chart recorder. :) with a piece of display software, so I can arrange whichever points I require on the screen.
+1 on the Red Lion PTV. I have three of these on our plc network displaying values on three 60 inch T.V.'s. Easy to program and get setup.
I'm wondering if anyone has any suggestions on how best to display SQL data on an RsView screen. As the operator is processing a batch we're...
4,136
hi i have a baumer vision unit picking up a QR code this is connected to a siemens 1200 plc. i have a IB18 In the device that is the start of...
9,358
I am using Pro-Face HMI with Omron PLC and using internal registers of the HMI for displaying data. If i disconnect my HMi from PLC the data is no...
1,397
Hi everyone, I'm having problem setting up a way to display live data on my HMISTU855. I am reading an analogue input value from a device and I...
1,246
This may come across as an ignorant question as I'm not yet familiar with Factory Talk View, but we have a small system that may be using an AB...
1,315
