Using Factory Talk to Read/Display PC Data
Jieve
Feb 2012
USA
274
This may come across as an ignorant question as I'm not yet familiar with Factory Talk View, but we have a small system that may be using an AB Controllogix PLC & VFD for controls, and will be reading specialized high frequency sensor data via DAQ PCI cards on the same PC as the HMI. Is it possible to program an HMI screen for system control, and also somehow access and display the DAQ card data on the HMI screen using some type of scripting within the HMI programming software?
Thanks!
Is is possible? Sure. Is it practical? Hard to say.
If you can get the data into Excel, or SQL, you can script the HMI to read it.
If you can use a direct OPC driver (like Kepware), you can read it directly, but "High Speed" is not something you will achieve
Honestly, using cards in a PC these days is a full-stop moment for me; while PC Architecture might seem stable, and invariable, after dealing with this for 30ish years now, I can tell you it isn't.
We've got a system here, built around the National Instruments (now NI) platform, JUST so that we know the interface will remain, and outlast the control PC's.
For my first time, I put a copy of Studio 5000 and Factory Talk Activation Manager on my customer's machine (On-logic Windows PC), then use remote...
2,495
I am using factory talk view studio site edition Version 8.20.00 . In that I added one media player to play video. But I cannot play it...
1,055
Hi, Rockwell level: Novice ; Siemens is more my gig. More formal training there. I own a license to FTV ME, the panel this runtime is located...
2,280
Hi all I have an application where i have 2 identicle machines which have an SLC in each. I would like to build a panelview application and be...
1,787
Hello there, world! The problem i'm facing up is about a registry I need to do in order to compare the set point versus the real variable I got...
1,581
