Mitsubishi PLC
Oh, I see, I had to get away from the US website and go to a European website.....
I dont see a trial version of GX Works 2 but I found GX works 3
which I am downloading,
I assume 3 is an updated version of 2?
JohnR
JohnR
GX Works 3 can use only iQ-F and iQ-R PLC Series(But when install they have GX Works 2 and GX Developer bundle with it).
For GX Works 2 first you should login at https://eu3a.mitsubishielectric.com then select these link.
https://eu3a.mitsubishielectric.com/fa/en/mymitsubishi/download_manager?id=10431
https://eu3a.mitsubishielectric.com/fa/en/mymitsubishi/download_manager?id=10432
ok, I had already been there and downloaded GX Works2 1.576
but found that it needed some code number to install.
is this version 1.501 you suggested going to install as a demo or will it need some code also?
I recommend you to use demo version beacuse code number are buy with license from Mitsubishi.
Wasan,
Well that's why I asked, the links you posted for ver 1.501 do not say demo either...
I'll see what I get when this demo of GX Works 3 gets done downloading, if GX Works 2 is bundled with it then I should be good to go, if not I'll look elsewhere.
Thanks for the help
JohnR
Update...
Got the GX Works 3 demo installed, and it shows an option to start GX Works 2, but GX Works 2 has to already be installed....
I went back and downloaded the GX Works 2 ver 1.501 that Wasan had suggested, and indeed it did have the option to enter the license code OR install in demo mode.
My USB cable showed up Saturday, and I was online with the PLC Sunday.
All is good in the world ;-)
Regards,
JohnR
126
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
89
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
113
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
158
