RedKingRory
Hello everyone,
This is my first post at this forum, although I don't know why I took so long to join. I've been working in this field for a few years now and have frequented this forum as a reference in the past. I'm looking forward to getting involved!
My problem:
I'm working with a nearly at-capacity PLC5/20. In the controller properties, there are the following details:
Program Files: 18, Words: 7949
Data Files: 41, Words: 7734
Overhead: 360
Memory Used: 16043 Words
Free Memory: 341 Words
I am attempting to address (in existing data tables) about 3 or 4 rungs of logic, including 2 timers, 1 additional memory bit, and a few compare instructions. It's a relatively minor change, but I'm concerned about adding logic into the PLC with this little memory left.
My question is; do I need to be concerned about "breaking the camel's back" so to speak, and faulting the PLC if I exceed the remaining memory during an online edit? Assuming there is space in the data table and that it's not being overrun, should I be concerned about this type of fault for an on-the-run change? Or will there be some kind of warning that prevents me from disrupting the running of the PLC?
Many thanks in advance for your time.
My problem:
Overhead: 360
