Vijeo Citect IO Disk Device Variable Tag Addressing
PLC.lady
Aug 2011
Somewhere
So I have need to display volume and run times on my screens for some equpiment. I recently got some help from support but things are still not running as smoothly as I want them to. I set up a new I/O Device that has Port Name: DISKDRV, Protocol: GENERIC, and Address: [RUN]:IODevDis.CDK.
I tired to create a variable under this IO device so that I can use it in my Accumulator for the runtime or totaliser. The frist few variable tags that I create with this I/O Device has data type ULONG, and the address was I102, I104, I106, but as I continue to increase in address', like I108, or I110, the Accumulator does nothing. Well it might be trying to do something but when I display the tag with address I108 all that I get is a "0" displayed and nothing else. I am not sure if I have the addressing correct or not. Is there anyone that could possibly help me? The purpose of this was to have a tag that I can use in an Accumulator that the runtime would be stored in, this tag cannot be a local tag, it needs to be a variable tag and since my primary IO device is non accessable to add more tags to the code I have to just work with what I had.
Thanks!
Just trying to get my head around it. Are you trying to send these messages over a network ?
If you are, Have you configured your I/O by doing the mapping ?
I am not sending these msg's over a network. I am not using msg'ing. I want to use the Citect Accumulators that they have. I want to count runtime and flow total etc. In order to use the Accumulator I need a variable tag so that it can write to it. I thought that I could use a local tag but I can't. I do not have access to the existing PLC therefore I need to create a DISK I/O Device so that I can create variable tags under that IO device and use them in the Accumulator to get what I want.
Citect Help is of no use in this regard. I am facing the same issue. Can somebody please detail steps to configure an accumulator in Citect 7.10 .
I am trying to count Run_Hours for a Pump. These are the tags I have created:
PUMP1A_RUN - Digital Variable Tag displaying Pump Run Status
PUMP1A_RUN_CNT - Local Variable Tag
Kindly explain how these can be cnfigured in the accumulator?
Did you set the accumulator Watchtime and Runtime or whatver it is in the citect.ini file ?
The default is 600 seconds , you need to change it to 1.
I am a newbie and am struggling through the manuals which is highly inadequate.
Kindly explain how do I set these parameters . I looked up in the citect.ini file but could not find the [ACCUMULATOR]watchtime and [ACCUMULATOR]updatetime functions. Kindly explain how these can be specified.
grvtg82
Citect project Editor, drop down "system" and click "accumulators"
then click "Help" this gives you general info.
so set [ACCUMULATOR]watchtime and [ACCUMULATOR]updatetime functions, open "Computer setup Editor" under "CitectSCADA Parameter Help" click "Citect Parameter listing".
Section A shows "Accumulator Parameters" click it
Behold! there they are. click the one you want, set the value and hit generate. Voilà
Chris
Hello, the system we use is Scada 7.5 series. We have usb key activ now we need additional key to make the system work, how do we solve this...
104
My system are taking data from RHT sensors, around 45 points. Now I want to make a function in which, if the data is #BAD or 0 in values for all...
496
I have DI module ICPCon M7024UD connect to my pc using COM3 MODBUS RTU and also RHT sensors are using MODBUS TCPIP.. The problem is, it cannot...
1,714
I need help with vijeo citect 7.4 as I use Modbus TCPIP to get the data, it turns out the address is having error.. For example, when I write...
911
Hi everybody, I have a simple question for anyone who knows.We cant try because system is working and we dont have a permission about it. We have...
743
