Mouse scrolling issue in RSLogix5
wildswing
May 2005
Sault Ste Marie, Ontario
281
I've run into an odd one. If I have my mouse scroll set to "single line", RSLogix5 scrolls in one direction only regardless of what direction I'm tuning the mouse. If I set scrolling to 3 lines, then RSLogix5 scrolling works fine. If I remember correctly RSL500 also does this. Anyone else run into this?
Same happened here...I found that in windows control panel under "mouse" my "connected device" was incorrectly identified. I think it showed a 5 button super-duper mouse. I switched to the one that nearest matched my actual mouse and it fixed it. It's weird that RSLogix ladder window was the only application that showed a problem.
For better wheel control, in many applications, check out the "Flywheel Download" here in the Downloads\Allen Bradley section. It's towards the bottom, called "Fly_Wheel.zip". Makes life in Logix5K programming much nicer.
Hi all, Should it be possible to scroll with your mouse within screens and lists in FTV ME (version 7 or 8) while working on your project...
19
14,674
When I scroll up or down on a ladder logic using mouse, some of the tags just fade away or disappear..never had this problem...is it the laptop or...
3,175
Hi, Does anybody know if it is possible to get the mouse position with Vijeo Designer Script? My goal is to cycle through all the panels by...
1,625
I have an older application that seems to rely on ICTMOUSE.DLL. I cannot locate this script extension using good ole google ANYWHERE! Would anyone...
2,016
I have some code that is working but only if linked to mouse button 1 and I really need it to be a button 2 or right mouse click function. The...
9,554
