Auxiliary control systems for cars
xzen
Jun 2006
Oslo
97
I have designed a few control systems, but always for some factory environment. Now I'm facing a new challenge. I need to build a control system for some mobile equipment. The task is in short to modify a small lorry truck and build some machinery on top of it. It's a farm machine that must be allowed for a lot of beating, dirt, water flushing and all kinds of abuse. It's going to be a rent out machine. Nothing wrong said about farmers, but I expect it will not always be treated nice.
Any of you with experience on building such auxiliary control systems for vehicles? I have questions regarding just about everything: Enclosures, power supply, buttons and handles, weather resistance, vibrations and not the least: which controller should I choose? I have most experience with Siemens S7-200 and S7-300/400. I also have some experience with several Allen Bradley types. But for me these PLC systems appear to be far too delicate, likely to fall apart by hitting the first pot hole in the road.
Pay very close attention to wiring type and routing. Cut no corner and spare no expense. "Farmers" spend a lot of time and money repairing wiring breaks. The fields are very abusive. What is the application? Will the operator be controlling in the cab or outside or both? Also remember that no matter how tight you seal something it will be exposed to the elements. Install lighting and illuminating button/switches because it could be used late in the night.
Before you start to look at specifics you need to have a think, it is way too easy to totally over specify a machine. For instance what are the consequences of the machine failing, is there any danger, are there big financial losses, how far away from you/support will the machine be. Then think about simplifying the system, the less there is on the machine, the less there is to go wrong.
The machines I am involved with aren't on a farm but are dragged around by farm tractor and then sit vibrating at the side of the road for a few hours. We chose to use a cheap system that allowed them to have cheap spare parts. So the PLC is a S7-200, for the HMI I use Beijer (PLCs and HMIs have so far lasted about 10 years but with occasional failures). Most machines have an on board 400/3/50 generator and I use standard Siemens power supplies. For other machines I use DC/DC converters to give me a stable 24V from the 12V battery system.
http://www.whatpowersupply.com/products.asp?cat=DC to DC Convertor
I don't generally use anything special for the enclosures but they are mounted undercover inside the machine with only the lid facing the weather. I use standard Moeller pushbuttons/indicators because they can easily pick up spares and no matter what you fit they will break them anyway.
Don't have any soldered wire connections because they will break, do use spring type terminals and do oversize cables.
Bryan
I thank you all for good suggestions. Especially you BryanG seem to have some experience in this area. Minimizing complexity and maximizing robustness seems to be a good approach. Also what Mtech mention about lighting and illuminating button/switches is important.
Hey everyone, Just wanted to see if anyone had any opinions on programming in a PLC that is essentially just being used to store data that's...
3,127
Hello guys, I will try to summarize my problem as follows Problem: ---------- I want to monitor the status (& also remote control) of a UL489...
3,300
Hi guys, This may be a dumb question, but here it is. Is it possible to use the ethernet auxiliary port of a G315 Redlion HMI to communicate...
2,965
Hello members, I have written a code for following program but my only doubt is about addressing of auxiliary contacts that are used for...
17
4,291
Dear, i was looking at the wiring diagram of the auxiliary circuits of PR123 trip unit of ABB MCCB (attached) i was able to depict K51 output...
1,574
