RSLinx failed to connect to CompactLogix through a gateway
cstca
Mar 2005
Toronto
33
System:
I have three testers, each tester having one CompactLogix L35E (rev. 15.3), 4 PowerFlex 700, one Panel View Plus, one Flex I/O and one PC, everything on Ethernet IP, with IP address setup to be 192.168.x.x. Between my local network and the plant network (10.x.x.x) I have a gateway: two ENBT/A (rev. 3.9) cards on a ControlLogix chassis, one on my local network (IP 192.168.x.x) and one on the plant network (IP 10.x.x.x). I’m communicating with one ControlLogix through the gateway using produced and consumed tags from all my CompactLogix processor.
Problem:
The MES is not able to reliable see my processors using RSLinx 2.43. Sometime the communication is okay; sometime they cannot see anything on my network. Sometime they need 5-10 min. to update all my tags. They are using Cisco switches and they are communicating all the time with 10 ControlLogix with no problem. Using Produced/Consumed tags, I see the ControlLogix, but it’s taking 2-3 min. to see the I/O LED on the ControlLogix steady ON when I’m establishing communication with the plant network. I’ve put an Ethernet snooper on the gateway and I saw a lot of CIP Connection Failure.
Is there anything that I’m missing in the gateway configuration? Do I have to do anything other than to setup the IP address on these cards? Did someone tried this configuration before and is working with no problem?
Thanks for any help.
CoS
check for no of connections in Clx Enbt
By typing Ip address of Enbt which is generating problem in Internet explorer you can diagnose the ethernet network
Hi Experts, I am using Matlab as an OPC DA Client to communicate with AB PLC rslogix5560. I can successfuly read from the PLC but when i try to...
1,577
Hello So I'm trying to install RSLinx 3.90.01 on my new computer (windows 10) and everything goes smoothly until i see this error. What can I do...
2,208
Hey guys, I hae an RSLinx that will not connect. So what I have is 5 machines, communicating in series from a DH485 to a coupler to ethernet to a...
1,394
Good Morning, Background: I wrote a project (logic in RSLogic 5000 v15, and HMI in FactoryTalk View Studio ME v5) on an old laptop. I brought the...
4,642
Running RSLinx 2.43 (lite) I am getting an error from RSWHO: Failed to open project Got the error for the first time this morning, I was...
5,138
