RSLinx "Failed to open project"
Seagullplayer
Aug 2005
Indiana
19
Running RSLinx 2.43 (lite)
I am getting an error from RSWHO: Failed to open project
Got the error for the first time this morning, I was online with a PLC about a week ago, everything was fine. Only two things have happened in the last week:
Our IT department installed some extra memory in the laptop.
One of the other Engineers used the laptop to get online with an SLC 500, I don't know if he had trouble or not, he is out for a week.
I call IT, they say reinstall, so I do, same problem.
After I close the RSWHO error, I get a second error:
RSLinx Failed to creat empty document
Any help?
I had a similar problem running a new install of Windows NT with RSLinx OEM v 2.30.01
RSWho would give me a "failed to create empty document" error.
Working with my IT guy, we reinstalled the software, and couldn't come up with any answers. We did notice that Internet Explorer was not working properly on the computer (the OS did not recognize it was installed).
RSLinx needs IE to run (it's on the install disk, and says so when you try to install). We ended up formatting and moving to Windows 2000, and everything worked correctly after that.
Fixed!!!!
The addition of the memory was not the problem, but they also changed the startup procedure on the laptop to make it boot faster!
We put the startup back to normal and the problem went away!!
Thanks for the help.
Hi Experts, I am using Matlab as an OPC DA Client to communicate with AB PLC rslogix5560. I can successfuly read from the PLC but when i try to...
1,562
Hello So I'm trying to install RSLinx 3.90.01 on my new computer (windows 10) and everything goes smoothly until i see this error. What can I do...
2,198
Hey guys, I hae an RSLinx that will not connect. So what I have is 5 machines, communicating in series from a DH485 to a coupler to ethernet to a...
1,391
Good Morning, Background: I wrote a project (logic in RSLogic 5000 v15, and HMI in FactoryTalk View Studio ME v5) on an old laptop. I brought the...
4,629
Good Afternoon: I need help on this problem, I am going crazy over here. I have been programming several PLCs with my laptop without any problems...
9,110
