RSlinx failed to identify device
aryautomation
Nov 2006
texas
34
Good Afternoon:
I need help on this problem, I am going crazy over here. I have been programming several PLCs with my laptop without any problems, But right now I am trying to connect to ML1100 , 1763-L16BBB and I get the message: (autoconfig appears to have succeeded, however RSlinx has failed to identify the device)
the version of rslinx that I have is 2.43.01(CPR6) which I think is a new one.
Any help will be greatly appreciated.
RSlinx lite
aryautomation said:
Good Afternoon:
I need help on thi sproblem, I am going crazy over here. I have been programming several PLCs with my laptop without any problems, But right now I am trying to connect to ML1100 , 1763-L16BBB and I get the message: (autoconfig appears to have succeeded, however RSlinx has failed to identify the device)
the version of rslinx that I have is 2.43.01(CPR6) which I yhink is a new one.
Which RSlinx driver are you trying to configure? The AB_EthIP or Serial DF1?
Also, go to Rockwell's web site and ensure you have the must up to date *.eds file
http://www.ab.com/networks/eds.html
Ian
New hardware, new hardware description file
RSLinx 2.50 and RSLogix 500 version 7.0 were the first versions to support the MicroLogix 1100 controller.
If you still have a problem with the DF1 driver after installing RSLinx 2.50, refer to RA Knowledgebase document 33050 to patch the hardware identity file.
RSlinx lite
You need at leas version 2.50
You can actually go online and donwload even with 2.43 but it will appear as unrecognized device...
Hi Experts, I am using Matlab as an OPC DA Client to communicate with AB PLC rslogix5560. I can successfuly read from the PLC but when i try to...
1,571
Hello So I'm trying to install RSLinx 3.90.01 on my new computer (windows 10) and everything goes smoothly until i see this error. What can I do...
2,201
Hey guys, I hae an RSLinx that will not connect. So what I have is 5 machines, communicating in series from a DH485 to a coupler to ethernet to a...
1,392
Good Morning, Background: I wrote a project (logic in RSLogic 5000 v15, and HMI in FactoryTalk View Studio ME v5) on an old laptop. I brought the...
4,634
Running RSLinx 2.43 (lite) I am getting an error from RSWHO: Failed to open project Got the error for the first time this morning, I was...
5,133
