plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old January 27th, 2014, 12:56 AM   #1
mehrdad
Canada
mehrdad is offline
converting signed to unsigned
Hi all,
I was wondering if there is anyway to convert a signed integer to unsigned integer in Rslogix 5000?
I know that I can use DINT for integers greater than 32767 but how can i convert a singed to unsigned number?
other PLCs simply have a INT to UINT converter function\block.
absence of int to uint converter is really causing serious issues for me.
thanks
Old January 27th, 2014, 07:58 AM   #2
Robobob
United States
Robobob is offline
Robobob's Avatar
I think you will want to use the ABS command.The ABS instruction takes the absolute value of the Source and places the result in the Destination.Place the absolute value of value_1 into value_1_absolute. In this example, the absolute value of negative four is positive four.
Old January 27th, 2014, 08:32 AM   #3
robertmee
United States
robertmee is offline
robertmee's Avatar
Quote:
That won't work if the OP's after 0 to 65535 unsigned.
Here's an example code to convert:
http://info.bannersalesforce.com/int...&Rendition=web
Old January 27th, 2014, 10:50 AM   #4
TConnolly
United States
TConnolly is offline
TConnolly's Avatar
Did you see the reply in the other thread you started on this same subject? This problem is super easy to solve. Don't make it harder than it needs to be.
__________________
True craftsmanship is only one more power tool away.
That's the beauty of processors, they don't have emotions they just run code - The PLC Kid.
Last edited by TConnolly; January 27th, 2014 at 10:56 AM. Reason: To attach picutre
Old May 17th, 2018, 05:35 PM   #5
preacher.ca
Canada
preacher.ca is offline
preacher.ca's Avatar
Thanks "TConnolly". Your posted solution was exactly what I needed to add to my Function Block Diagram.
Old October 11th, 2018, 03:33 PM   #6
williamcreis
Brazil
williamcreis is offline
Saved-me
Quote:
Did not know the function, saved my life
Old October 18th, 2018, 02:47 PM   #7
Petr_Broza
Canada
Petr_Broza is offline
Simply clever
Old January 18th, 2019, 01:09 PM   #8
psboy2000
United States
psboy2000 is offline
Helpful
Thanks for the simple fix TConnolly.
Old June 3rd, 2019, 04:17 PM   #9
autonow
United States
autonow is offline
Cool Nice solution. Now I need to go the other way I have a dint and need to goto two ints where the two ints are swapped
So int2 is the first part of the word and int1 is the second part
So when the value of int2 goes over 32767 It goes negative and int1 picks up the remainder. Does that make sense
Old June 4th, 2019, 01:15 PM   #10
CapinWinky
United States
CapinWinky is offline
CapinWinky's Avatar
Logix doesn't have unsigned integer types at all, which is weird to me.
__________________
Cycling power is a sign of weakness.
Old June 4th, 2019, 01:17 PM   #11
ohnedich6
United States
ohnedich6 is offline
Logix added unsigned integer types in V32 of Studio 5000. Just a FYI.
Old October 8th, 2019, 07:47 PM   #12
TheWaterboy
United States
TheWaterboy is offline
TheWaterboy's Avatar
I know this is older - but I have v32 and UINT is an option but is unsupported in the 5380 series PLC. Go Figure.
Old October 8th, 2019, 08:07 PM   #13
dmroeder
United States
dmroeder is offline
dmroeder's Avatar
Quote:
Are you sure? I'm fairly certain I tested this and it was only available for the 5380 and 5580 (5069 and 1756-L8x).
Old October 9th, 2019, 08:59 PM   #14
TheWaterboy
United States
I just went through it yesterday, The datatype is there but when I try to use it I get the unsupported message. V32.11 as I recall.
Old October 10th, 2019, 11:10 AM   #15
Firejo
United States
Firejo is offline
Firejo's Avatar
I have a 5380 L306 v32.011 and Logix designer 32.00.00 (CPR 9 SR 11). I'm able to configure, download and use a UINT without any errors or notices.
Just an FYI.
__________________
Go Hawks!!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
signed and unsigned guest LIVE PLC Questions And Answers 13 September 12th, 2017 01:45 AM
Signed & Unsigned Integers dbh6 LIVE PLC Questions And Answers 8 March 20th, 2013 09:36 PM
Modbus Signed vs UnSigned Issue lostcontrol LIVE PLC Questions And Answers 5 May 24th, 2011 01:34 AM
Signed / Unsigned integers with a PanelView shoelesscraig LIVE PLC Questions And Answers 6 February 26th, 2010 04:50 PM
Number formats in PLCs dexdyne LIVE PLC Questions And Answers 11 July 13th, 2007 09:58 AM
