ceilingwalker
Hello all. I would like to know if I could get some recommendations for sending a Power Flex 755 out for repair. It is for a frame size 7, if that makes a difference. I have send bad boards to Radwell in the past however, this is an entire drive. I keep getting a fault code 13, ground fault, even with the load disconnected. Sometimes the drive will power up and go 5 minutes before faulting, other times it faults immediately. I realize I can search for repair shops however, I would rather use someone recommended by you folks here. Thank you.
