MC35i terminal
kouim92kostas
Aug 2019
Greece
32
Hello experts!
Can you help me with mc35i and how I can program it?
Do i have to declare the sim number inside the modem?
I want to send SMS From CPU 315 2pn/dp and cp340 when an alarm appears to 3 different phone numbers.
Hello experts!
Basically you need AT commands to send with ascii from PLC and also listen modem replys before next command.
Tutorial is this, you can code it, but it isn't easy from blanck.
https://www.developershome.com/sms/howToSendSMSFromPC.asp
Siemens have at least this:
https://support.industry.siemens.co...erial-cp-or-cm-and-modem-md720?dti=0&lc=en-WW
For only 3 messages I would use remade SMS alarm messager with few DI inputs.
Is there any kind of virtual GSM modem so I can test my program without uploading it to PLC(CECC-LK)? I don't have this equipment at home and I...
1,180
Hello, i am new in programming and i must write a programm, witch sends alarm messages (SMS) to mobile phone. I have bought CP340 and MC35i for...
2,348
In the past, we have used AB 1492 feed thru screw terminals a lot. Lead time on these with our distributor is terrible. Is there an almost...
138
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built...
246
Hi all, i have several Proface GT2400 terminals and i need to get the software and interface cables and i have several questions. I am assuming...
171
