Terminal Blocks with Fuses and MOVs?
Ruskied
Jul 2018
Valencia PA
19
I'm trying to include MOVs and fuses for solenoid PLC outputs in a panel with limited space. Does anyone know of terminal blocks that have built in MOVs and fuses? I know of fuse terminal blocks and suppressor terminal blocks but not both. If that doesn't exist, is there a reason why? I might be missing something fundamental.
Any insight would be greatly appreciated.
Thank you for your time.
Yeah, that can be done. However, panel space is limited. Was hoping to use AB 1492-FB1J30 and Phoenix TTC-6-MOV-C-120AC-UT-I but it takes up too much space and won't fit. I can't believe such product doesn't exist.
How much you have room to up. Thinking that you could raise another din rail with bolts above movs and install fuses on above. Not as serviceable thought.
What is the difference between Siemens terminal block 6ES7193-6BP40-0BA1 and 6ES7193-6BP40-0DA1? Can they be used interchanged for an analog...
1,227
Currently using a AB 1492-FPK2, plug in fuse but now finding alot of these are.. touchy with connections. the terminal block they are plugged into...
1,357
OK, some internal "discussion" going on in my world about what is preferred in the industry for a three position connector, a spring clamp type or...
42
16,259
Hello, A couple of questions regarding NEMA schematics and terminal block labeling. 1) I am familiar with the DIN designations for components...
3,115
So I am putting a control system together and all my I/O cars are without terminal blocks. What resource can i use to find out which terminal...
2,722
