Mitsubishi CC-Link
Apr 2002
No income tax, no capital gains tax. Freedom!
8,390
I just got visited by the CLPA ( CC_LINK Partner's Association ).
Obviously they were trying to get us to support CC-Link with our products. I want to get opinions about CC-LINK, the more the better.
Just in case the poll options don't work, I would like to know:
1. If you are a Mitsubishi users.
2. Have you used CC-Link
3. Have you done motion control
4. Have you used CC-Link to communicate with the motion controllers.
5. Is CC-Link easy to use?
6. Would you rather use Ethernet?
CC-Link looks like it would be simple enough to implement. I just wonder if it is suitable for motion control. Sending a command with position, speed, accelreation and deceleration would require a couple of stations and the parameters would need to be transfered using the transient messages.
Any thoughts?
1. Yes
2. Yes
3. Yes
4. Not yet (but it looks like I might very soon... )
5. Yes (* - when planed well)
6. Yes
a) Manual sucks. Just half a page in decent english would be
way better. My local (Toronto) distributors and Mitsubishi
Tech Support were not (are not) helpful. Only guys who
ever managed to answer any question are from Tech Support
in Chicago.
b) Pass through connection doesn't work 100% with everything
unless master and slaves are same family (it does work
for PLCs to exchange data but Mitsubishi's own ActiveX
doesn't work very well).
c) Very limiting mapping scheme. On one project I was forced
to connect couple of existing systems which were done by
different vernors. I couln't make it work until each PLC
had same amount of free devices (ok) in same range
(what the hell!? (n) ).
Problem was that two machines had their memory use pretty much
maxed out. Free range on one of them was around D1000
(with total of some 2000 D-words), while the other had
everything pretty much used up until D20000.
Maybe there is a way to it, but I didn't have time to
investigate too much. It was faster to remap some of the
used devices in one of the machines.
Also I've found some discrepancies with the manual.
(well, manual sucks anyway... :nodi: )
btw. what are your products?
I thought everyone knew.
I haven't advertised it because Phil frowns on that.
We make motion controllers that fit in PLCs or communicate over a field buses such as Ethernet, Modbus Plus, Profibus DP and RS485 etc.
To be succussful as a third party supplier one must be as compatible with other products as possible. That is why I am interested in CC-Link, but I would much rather be able to communicate with the Q series using Ethernet. Unforutunately, Mitsubishi has kept their Ethernet protocol proprietory. :(
I have use CC Link several times. The biggest problem I have had is failure of the CC Link master module in the PLC to communicate with the remote devices. 2 CC Link masters in the rack. One stops communicating with the remotes. Swap the masters over and all is well. Very puzzeling. Our local Mitso distributor at a loss. I might add that they are very good but could not solve that one. Some time later loss of communications again. Swapped the CC Link masters and all was well again. Bit of a worry. Would rather use Device Net. Do not like Ethernet but would probably be OK for this application.
beerchug
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
103
I’ve not had a great deal of experience with CC link (TP) so looking for some ideas. I have several iQ-R PLC’s most of them are on an Ethernet...
1,389
Been having a rough few weeks getting CC link working on some old Misubishi A2S's. I've been able to write configurations to the master module...
1,833
Hello Everyone I have a Q02 and Q06 CPU's with Ethernet and CC-Link modules, I need about 5 24vdc inputs and 5 24vdc outputs about 100ft away, I...
1,732
Hi Everone, i need a mitsubishi plc software.please tell me the link which i download the software.thanks
3,156
