Mitsubishi CC Link Master Module A1SJ61BT11 Won't save to EEPROM
ratdude747
May 2016
Madison, IN
Been having a rough few weeks getting CC link working on some old Misubishi A2S's.
I've been able to write configurations to the master module (A1SJ61BT11) with GX-Configurator CC but even after downloading to EEPROM (Not buffer memory) the configuration gets wiped on reboot.
I've had two modules do this to me. Looking through the manual there doesn't seem to be any dip switches that would be of use (unless I need to be in a different mode?)
At least one of the modules is new untouched. I say at least as the tool shop my employer is using had to buy a used module as one of the two new ones we provided was missing the terminal block and I don't know if they swapped the block or the entire module.
Otherwise I'm able to read from and write to my I/O CC-Link modules w/o issue, after re-loading the configuration.
Anybody have experience with these old things?
I may have answered my own question. I tried the GX-Configurator CC manual, and found this:
attachment.php
šŸ™ƒšŸ““
Looks like I have something to try tomorrow...
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
105
Iā€™ve not had a great deal of experience with CC link (TP) so looking for some ideas. I have several iQ-R PLCā€™s most of them are on an Ethernet...
1,391
Hello Everyone I have a Q02 and Q06 CPU's with Ethernet and CC-Link modules, I need about 5 24vdc inputs and 5 24vdc outputs about 100ft away, I...
1,735
Hi Everone, i need a mitsubishi plc software.please tell me the link which i download the software.thanks
3,158
Hi Guys, Has anyone ever worked with an IAI robot cylinder position controller PCON CA and if so can you help me on how to program it with...
2,593
