Networking Xycom HMI that run wonderware intouch apps
wcklingler
Oct 2005
ohio
We have 6 xycom hmi's that are running intouch apps. These hmi's are linked to plc's with modbus. What is a cheap way to network these screens to another master xycom? All of these screens run windows xp.
Thank you for the reply, and that is what I am going to do in the near future with 10 units. My problem is that I need to link 1 display to a desk top pc. Both screens have intouch and once linked I can poll data from 1 to the other. What I would like to do is use serial or parallel connection if that is possible. I do not have an ethernet hub and would like to show a small project like this to my employer in hopes of them buying the hub, I don't need to poll much data to sell this. Any help I would appreciate.
I was hoping to use mynetwork places in windows and just do a direct connect with the desktop. I will be using a xycom display. If someone could bench test this with a parrallel cable I think i can establish coms from intouch to intouch any help would be appreciated. I don't have a xycom display at home and the IT people are resistant to networking these operator displays. But for maintenance there is alot of use.
Just go buy a network hub, they are around $60.00 at Walmart, or even cheaper on ebay. You will have to set up a seperate IP address for each Xycom, and PC. You will also have to set a gateway and subnet mask for each.
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
204
guys: I have a problem with my IP configuration. my organization networking has 2 subnets. 10.0.0.25 and 10.1.0.25 both under 255.255.255.0 all...
578
I have a question about IP addressing and Networking. I have a PLC with following IP address 10.1.0.120 this is an static PLC PLC is working like...
2,124
I swear I post this yesterday but can't find it. Don't see any notification about the post removal either. Maybe my memory is malfunctioning...
2,592
Hello all. I have a system with 4 different machines, each has their own PLC. I also have a RC in this subnet also. I created a server PLC that...
473
