How to control duty cycle in PWM from signal control u to controlling dc motor
zeta
Aug 2007
bandung
Hi friends...
I have a problem about PWM (Pulse Width Modulation) in MRAS design to controlling dc motor.
I have the algorithm to get control signal,
u(k)=c1(k-1)y(k-1)+c2(k-1)y'(k-1)+c3(k-1)r
e(k-1)=y(k-1)-ym(k-1)
c1(k-1)= - sigma from i=0 to i=k-1 {e(i)y(i)
c2(k-1)= - sigma from i=0 to i=k-1 {e(i)y'(i)
c3(k-1)= - sigma from i=0 to i=k-1 {e(i)r(i)
This Algorithm applied on PLC Siemens S7200 in STL. And this result giving U always decrease...
My problem is how to drive PWM from u (control signal). It means how to make the duty cycle value from u
More information :
>I have s Siemens PLC S7 200 series.
>I don't work in PWM mode, but I try with high speed counter
This program in STL:
Network 1
LDN M0.0
TON T32, +100
Network 2
LDW>= T32, VW50
= Q1.0
Network 3
LD T32
= M0.0
For example if the value of VD50 = +40, so PWM--> 60 on and 40 off.
>Base speed about 70% duty cycle.
>I have the algorithm to get control signal:
This Algorithm is applied on PLC Siemens S7200 in STL. And this result has U always decreasing...
My problem is how to drive PWM from U (control signal). It means how to make the duty cycle value from U.
Dear all, I am doing a PLC program for 2 duty and 1 standby pump rotation control by using Mitsubishi Q series PLC. The control sequence of the...
10,119
Hi, I've recently tuned a PID for a level control in a channel application. Everything was functional fine until a new feed pump was added to the...
10,231
I need to control 3 pumps (Duty, Assist, Standby) The duty pump will be controlled from a PID loop based on a flow input. When the PID output...
21
17,192
Hello: I'm looking for a heavy duty single turn potentiometer with a dial 4-5 inches in diameter. Does anyone know who makes them? Thank you, George
3,050
Dear All I want to write some stand alone PLC SLC500 code for Motor Duty / Assist1 / Assist2. Basiclly I have got 3 motors work on a Duty /...
2,568
