TConnolly
puravdagli said:Peter,
I really like your solution.
I like Peter's solution as well. I've been watching this thread for ideas. I have a hydraulic press purchased from China. The iron is not bad but the hydraulics really are a POS (and leaked even when brand new), as were the original controls, which have been partially upgraded. A full upgrade is planned. In the meantime I'm trying to work with what I have and improve it without interrupting production.
The system has two fixed displacement hydraulic pumps. Both pumps are on VFDs. The main ram is stroked in and initially pressurized using the larger pump (ramp is PID controlled). When pressure reaches 1600 psi (110 bar) the main pump turns off abruptly and a very small pump on a VFD (also PID controlled) turns on and runs at low speed to hold pressure. I have the two loops tuned so that they perform very well (Thank you Doug Cooper), but the transition from the large pump to the small pump is rough. Anyways, there are some interesting ideas here that I've been considering.
