AWG wire sizes in the European Union
TConnolly
Apr 2005
Salt Lake City
6,152
Has there been any recent changes regarding the use of AWG wire sizes in panels exported to the EU? Its been about 10 years since I sent a panel to the EU and I was wondering if anything had changed in that regard. In the past we've used AWG wire and rated it accordingly to the nearest smaller IEC wire size, eg, a #18 wire (.82mm2) rated as a .75mm2 wire, #12 wire (3.31mm2) rated as a 2.5mm2 wire, etc. Is that still acceptable or have they tightened down and required mm sized wiring?
Thanks. What I was meaning was if there had been a change that required us to use strictly metric sizes instead of appropriately rated AWG sizes.
Not that I've heard of. Last year I was on a project on an oilrig here in scandinavia that had alot of old chinese cables in all sorts of odd sizes and that was apparently ok.
I am supplying a control system to Singapore. The range of AWG wire size for the main breaker is 3/0 to 500 mcm. How do I put this in European...
2,770
The Phoenix terminal blocks are in place, and they accept a 10 AWG wire. Now, the customer wants to connect some 8 AWG wires (mechanical reasons...
5,651
Dear Automation experts, I want to use the existing lonworks network which uses AWG#20 Shielded twisted pair for my Profibus system because I find...
2,983
Dear all. We use copper wire, but in specification of copper have term "AWG" but, it stand for of, it isn't?. Thanks
1,696
Does anyone have experience wiring this type of analog pressure transmitter up? It's 4 wires. 3 blacks and 1 green which I assume is earth...
294
