Wire size conversion American AWG to European
NetNathan
Nov 2011
Corona, CA
2,199
I am supplying a control system to Singapore.
The range of AWG wire size for the main breaker is 3/0 to 500 mcm.
How do I put this in European standard?
1 searched it but I get all sorts of different conversions sizes.
https://muellergroup.net/technical/metric-awg-to-mm2-conversion-chart/
surely there is a real standard......🤞🏻
The attached link looks reasonable...
edit - scott's link looks totally different....
See...
That is what I found....different sites have different sizes??????
But..this is what I found the most..
3/0 = 95 mm squared
500 mcm = 240 mm squared
Ah, good old AWG. Because why use an actual measurement to describe the size of your cable when you can use a totally unrelated number instead? :D
Come now, you don't want to make electrical work too easy.. otherwise everyone will be doing it!
I like to submit the odd invoice with interesting descriptions... like a recent radio antenna i had to re-align was described as "Found radiating element misaligned by more than 36 degrees. Re-aligned using Eyeometer. Tested RSSI, all OK."
Because lots of people are used to it. And, truth be told, how often one actually measures the cross-section of a conductor? When all you do is read a label or a print mark, it is just some number in either case.
An interesting note to using AWG instead of cross section...
an example..4/0 THHN will not fit in same connector as 4/0 weld cable. The fine stranding makes the diameter larger, so you need the next size larger connector.
Hi everyone ! A multiconductor wire 4x2,5mm2 would be ok ? Normally a 10hp - 400V motor would pull 16-17A A 4x2,5mm2 wire could carry around...
1,857
In reference to this thread today I have to install some more C55 contactors with # 4 wire but the wire is standard MTW and will not fit with a...
2,042
my PLC Input contains only push buttons , limit switches, scanner signal etc, for which the PLC doesn't consumes much current.So if i use a...
9,421
Ok I know this is not the place to really ask this but. I need to know if 2 0/1 wires are the same as one 300 or 350 cmc wire? We need wire...
3,144
I was wondering if anyone knows the wire size for a 3 phase 200hp motor for an air comp the uglys book only goes to 150hp motors also where...
3,335
