Wire Size Question
Tim Ganz
Dec 2010
Dallas, Texas
689
In reference to this thread today I have to install some more C55 contactors with # 4 wire but the wire is standard MTW and will not fit with a ferrule. I though surely that would fit with not issues.
Why would # 4 MTW with a ferrule not fit?
Did you crimp the ferrule before trying to insert it into the terminal? Some people try to use the contact to compress the ferrule around the wire; that's typically a bad idea. A crimped ferrule should fit.
SceneryDriver
Ok I know this is not the place to really ask this but. I need to know if 2 0/1 wires are the same as one 300 or 350 cmc wire? We need wire...
3,146
Hi everyone ! A multiconductor wire 4x2,5mm2 would be ok ? Normally a 10hp - 400V motor would pull 16-17A A 4x2,5mm2 wire could carry around...
1,859
I am supplying a control system to Singapore. The range of AWG wire size for the main breaker is 3/0 to 500 mcm. How do I put this in European...
2,748
my PLC Input contains only push buttons , limit switches, scanner signal etc, for which the PLC doesn't consumes much current.So if i use a...
9,423
I was wondering if anyone knows the wire size for a 3 phase 200hp motor for an air comp the uglys book only goes to 150hp motors also where...
3,336
