Backplane 1756 EN2T communication Issue
RockyNivas
Mar 2019
United Kingdom
57
Hi All,
I am using Backplane 1756 EN2T Master PLC (AB PLC) and trying to communicate with 1769-L30 ER (AB PLC). It has connected with Ethernet and I am trying to set up the message instruction to build the communication, but the master PLC status is always showing faulted since I have selected the slot and other stuffs precisely.
Please advice do I need to look into any other settings in that message instruction.
Thanks in advance
Producer/Consumer, as jstolaruk mentions, is the preferred method. However there are reasons why you would want to use MSG instead. Regardless of which method you use, if you add the target PLC to your I/O tree, you will be able to pick your target controller by name and not have to mess with configuring the path manually.
Please explain exactly what you mean by that.
My guess is that you entered the CIP Path manually, and that the MSG instruction fails with a .ER bit when you trigger it.
What model of CPU and firmware revision are you using ?
The more information you can provide, the better the advice will get. Until about ten PM tonight, at which point I predict a sudden and pronounced decline in my judgment and precision.
I have a 1756-L55 and an ENBT that have been working great. I then replaced the ENBT with an EN2T/A and it still worked. I now need to get an...
3,879
I noticed something that’s mostly just a curiosity. Maybe someone here knows. An IT system is reading a L82 with the on-board IP and 1,0 added...
718
Good Morning , We had our 2nd episode in 4 weeks with a 1756-L62 processor causing a backplane communication issue , that caused us to...
2,568
I've installed a new ControlLogix PLC rack and addressed the ENBT/A module. Remotely, I can go into the http://ipaddress and see everything...
2,620
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
132
