Help with ST/LD program
Silver TT
Mar 2017
Calgary
Hello, I'm working on a program which sends a modbus message and then re-sends the same message if it does not receive a response. I send the modbus message from a ladder diagram and then call a UDFB which checks if the slave sent back a response by monitoring a coil called "successful_Message". The UDFB should allow the message to re-send a certain number of times, and then stop. I can't seem to get it to stop though, it resets to zero and keeps sending!
Any help is appreciated.
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
60
167
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
577
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
330
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
473
