nedlecky
Hi! I need help converting an old MicroLogix 1100 project to Micro 820.
Project Details
I have an old MicroLogix 1100 program that has been in service for 10+ years.
I want to convert it to a Micro 820 program. Yes, there's a converter in CCW, but it requires an export from RSLogix Micro into SLC format and I only have the RSLogix Micro Starter code that won't do that.
AND... I'd like to have someone who knows the 820 so I can get experienced eyeballs, advice, and a sanity check on all this old 1100 code.
More Details
The application receives hardwired fail bits from a vision system and uses either time or encoder pulse counts (on an HSC input) to fire a reject mechanism. Speeds are up to 900/minute, but could go higher someday. At 900/minute, the 1100 has been working just fine.
The code has a pretty small number of settings and inputs which come over EIP from a C# GUI that I wrote.
The PLC has just a few hardwired outputs... turn some indicator lights on/off, fire the reject mechanism, turn the line off.
There's a calibration mechanism where you set an offset at low speed and set another at high speed and then the offset scales based on encoder pulse rate... that part I don't fully understand but it looks straightforward.
It would be great to find someone to sanity check and get me started/most-of-the-way on the conversion!
- Someone who already knows MicroLogix 1100 and Micro 820
- Someone who knows how to convert
- Someone who understands basic encoder/HSC use and part reject tracking??
Happy to compensate you for your time and knowledge!!
Project Details
More Details
