Versamax Micro Connection Problem
h_assh
Aug 2019
Karachi
I am trying to connect with Versamax Micro (IC200UDR005-BG),PLC is showing OK Led while I am using Proficy Machine edition 9.5 it's just keep on connecting message but doesn't connect, I have also tried SerialComTest but it didn't help.
tried it already, it's not working.. and the PLC is Versamax with Serial port (RJ45 Connector) not the UART cable
With cables that are handmade most of the time there is a issue with the RJ45 end not making a good connection, I would double check it.... RJ45's are made to be used with solid cat5/6 odds are your wire is stranded so you may need to make a couple ends before you get a good one
Also make sure that you properly identified pin 1 on the RJ45 end. On the PLC port, pin 1 is toward the bottom.
I have double checked the connectivity with multi-meter and it seems to be fine
I have been trying to connect Versamax Micro PLC with PC but I am unsuccessful so far, I am using Proficy ME. Previously I have been trying to...
1,311
I'm having problems connecting with a GE VersaMax Micro PLC. I'm using VersaPro software, com port, to SNP (15-pin) connector on PLC. Connecting...
5,812
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
390
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
429
Can anyone help me getting this comms connection set up? I am using Port 2 on the Versamax ICU200UDR005-DK, set in SNP with port settings Baud...
1,549
