Display time from plc tag in factorytalk view se
rsuser
Dec 2016
netherlands
Goodmorning,
I think this is a very basic question, but i'm not able to find the answer anywhere. I would like to display the date/time from a plc tag(date/time format) in factorytalk view SE.
If i use a numeric or string input it's not showing anything. If i use the date/time display object in factorytalk I am not able to assign a tag to it.
If i use the tag label object it can also not get the correct format.
How to get the the date/time to display in factorytalk view SE directly from a plc tag (in date/time format)?
PS. this is not a running time, but a timestamp made in the PLC.
Thank you for your answer. This is indeed the way I intend to use it as well, however it bothers me this is the only way to use it. But thank you anyway!
Hi, i work on the display where i have list of tags. This names of tags are retrieved from external database. The full name of every tag is...
3,848
Hello everyone, Using FactoryTalk ME IO face plates, I want to see the descriptions of the IO tags. The version I'm using now is FTME v7. I've...
2,117
Hi I am a beginner to the GE PLC. I am working on a project to install two new viewmarq display. Has anyone ever connected or worked with this...
376
I have a robot cell controlled via PLC. I want to use an output from the PLC, based on whatever part number the cell is processing, to open a...
898
Hi all, I am looking to replace an old set of trip amps that used a complex thermocouple setup that did averaging electrically. I will run back...
2,994
