ControlLogix 5000 compare?
Patrick
Apr 2007
Washington State
96
Is there a function to do a program compare in ControlLogix 5000 like there is in a SLC 500 or a PLC 5? If so where is it located? I was told do a file compare on a program. I have done this several times before with the SLC500 and PLC5. But can not find this in the ControlLogix program.
Thank you,
Pat
If you are speaking of doing a compare of two programs, then there is a seperate program for this task. It used to be a part of the RSLogix program, but with 5000, Rockwell has seperate applets for doing such a trick.
If you have the RSLogix5000 cd's it should be on there. It is simply called RSLogix5000 compare tool.
Otherwise you can download it from Rockwell's website.
I'm attempting to read tags from a 1756L81E(FactoryTalk Logix Echo) controller using the PLC4J api. I have one read and one write bool setup in...
2,321
Hey All, I'm currently building a control system for a large building in a industrial setting. Doing lighting, vent, roof control, door access...
3,526
I know there's the DTOS Function, but I have a value of "35" that is really "0035", and that's how I want it converted. Looks like the function...
1,535
I am an Electric Engineer working as a maintenance engineer and manage some technician on the production hall now but in the past, I mostly focus...
3,580
I'm not a PLC programmer, so bear with me here ... I was making an AOI with a bunch of BOOL inputs and realized some of them were actually...
1,837
