RSLogix 5 program migration to RSLogix5000
Unregistered
Guest
U
Hello,
I was wondering if it is possible to import/migrate an existing RSLogix5 (PLC5/30) application into RSLogix5000 (Controllogix), or do I have a re-write on my hands? Thanks
Doug T.
It is pretty clunky, but it will convert the logic.
You end up with poorly named tags and very poor memory utilization.
In a pinch I would use it. I would validate very carefully myself though. I would not trust it 100%
Given the time, you would be far better off to write the code and create the tags by hand.
I'd back up what RSL said; what you get is a CLX "dumbed down" to look like a PLC5. It'll scan faster (and probably cost a bit less) but won't take advantage of all the advances that the CLX offers. I'd use it to get the overall "shape" of the ladder, especially if you've invested some time in debugging it on the previous platform.
You can simply drag and drop ladder from Logix5/500 to Logix5000 but this won't generate the tags for you.
In case you're still interested in this, AB has a manual you can download which may tell you more. Thought I'd throw it at you if you still want to play around with it.
Russ
Converting PLC-5 or SLC 500 Logic to Logix5550 Logic Reference Manual1756-L55Reference Manual1756-RM085B-EN-P
I am completely stuck on building a ladder program that requires a start button to be pressed 3 times to turn on motor 1. Then motor 2 starts...
20
649
Hi. I came into a problem that was buried in my memory. I had a list of modifications to do on 2 RSLogix programs. So I tapped in the IP...
1,113
Hello all, I am working on a project on a CompactLogix L16ER-BB1B plc, and I was given a program that is on version 20.019, while my plc is on...
1,892
I have been tasked to upgrade some SquareD PLCs at our plant. I have done several of these upgrades without any issues. However, I have now met my...
2,462
