hi
I have a machine with a compactlogix plc and a powerflex 755 which the Machine is running ok, but I would like to create a hmi screen with the drive info on faults,trends current ect , Im aware of the Add on instruction But never used them before, which you need the template for the hmi which I have added to the hmi I understand that .
now this is the issues the existing program
has the Ethernet drive in the program which is call Agitator the Tags for the drive a called Agitator:I and Agitator:O which are
in the Ladder to control the drive .
if I what to use the PF755 template in FTV then do I need to have the RSlogix5000 PF755 add on block ? or can I assign the Agitator tags to operate the Faceplate ?
and how do I assign the tags to the Template ? is it in Parameters? #1::[PLC]Agitator?
thanks stu
thanks stu
