ControLogix FBD JSR
EIEIO
Feb 2012
Edmonton
Good day
Does anyone know if the execution order of JSR's can be controlled properly when done in FBD? It seems that they do not execute the same as when done in ladder logic.
Regards
Brian
I forgot to mention that this is for a ControlLogix application.
Select the FB's properties to see the execution order for the block. You can't change it directly, but you can influence it with the use of input & output "wire connectors".
Suppose you wanted to JSR to routine X at the beginning of your main FBD and then JSR to routine Z at the end of your main FBD routine? How does one condition the JSR inputs/outputs to accomplish this?
The easiest way, is to make several different FBD routines, and then call them in whatever order you want from a ladder routine.
I'm having a hard time envisioning why this is needed though.
Can anyone confirm that using contrologix 5580 controller is not possible to work with powerflex 527? It's been a couple of days now that i am...
1,228
Hello, I have a flow control PID that keeps locking up. It seems to control fine but after a while the output no longer moves. For instance...
981
Hi everyone, I can't add any modules to the Controllogix backplane and it doesn't matter online or offline. Both is not working. Please see the...
3,026
Hello, I have a question regarding the possibility of using messages instructions to communicate between: PLC5/80E Series D - CE Water Mark...
3,099
I have a customer who wants to control his DCS800 drives via Ethernet, so I have bought two RETA-01 cards. At the moment they are connected via...
1,011
