Allen Bradley Panel View 550
PIM
Aug 2003
Can anyone tell me how the change the screen contrast on my Allen Bradley Panel View 550. The numbers are so faint I cannot read them.
First-
Check the backlight. There is a compartment on the back of the Panelview that contains the backlight bulb. I have seen several of these burn out.
If that is not the case, and you have a keypad (not touch screen) Panelview, press the left and right arrows simultaneously to get to the "config. screen" from there you should be able to find the video setup(not sure of the correct terminology).
jthornton said:
the right and left arrow keys also works with the touch version...
Only if the right and left arrow keys have been included in the Panelview program. If PIM had replied that he had a touchscreen, I would have elaborated.
Where would they be included in the panelview program? I don't see anywhere in the PanelBuilder where you can include or exclude the arrow keys... Can you elaborate a bit for me?
John
This is from the PV troubleshooting manual
Screen objects are not visible.
1. Correct power is not applied.
2. Contrast or intensity is not set correctly.
3. Terminal is in screen saver mode.
4. PV550 backlight lamp is not on.
5. Terminal’s backlight is burnt out.
1. Verify power connections.
2. Access Screen Setup on the Configuration Mode
menu and adjust the contrast. On keypad
terminals, press the left and right arrow keys
simultaneously, then press [F9] or [F15].
3. Access Screen Setup on the Configuration Mode
menu to see if terminal is set for screen saver
mode.
4. Access Screen Setup on the Configuration Mode
menu and turn on backlight.
5. Replace backlight.
To access Configuration Mode on keypad terminals:
· If an application is running, simultaneously press the Left and
Right arrow keys on the terminal keypad.
To access Configuration Mode on touch screen terminals:
· press the GoTo Config. Screen button on application screen or
· press the filled box in the lower right corner of the screen
during powerup.
If I have a Panelview 550 (touchscreen only) and the application I write for it has nothing but momentary PB's and screen selection buttons, there would not be, on any screen, left or right arrow keys.
And...on a touch screen Panelview, you can't press more than one object at a time.
on my Allen Bradley HMI i want to put a login and logout screen for when my operators want to reject a part in production i want to eliminate this...
1,513
Hello everyone, im new in Allen Bradley World, i alredy know how to use factory talk view and with manager i have alredy upload all runtime...
1,718
Here at My work we purchased a system from an Automation vendor a year or so ago and the Allen Bradley PLC and Panel View Plus give control to...
4,336
Hi all, I've been asked to edit a Panel View C400 but i'm unable to communicate with it. The screen was installed by A.N.Other and I tried using...
4,506
Hi gents, In my allen bradley panel view plus 1000 HMI have three levels of password protection, ( OPERATOR, MASTER and ADMIN). I would like to...
3,192
