Older FactoryTalk View not working with newer FT Services Platform
MartyMaucher
May 2014
Pensacola
91
So, I grab my ~2003 FactoryTalk View Studio software off the shelf and install it in Windows 7. When trying to run it, I get "FT Services Platform 2.10 is required)" even though FT Services Platform 2.30 is already installed.
Any idea why FT View Studio won't work with the newer FT Services Platform?
System:
- Windows 7
- FactoryTalk View Studio ME 5.00.00
- FactoryTalk Services Platform 2.30.01
- RSLinx Enterprise 5.30
My disclaimer is that I only work on a PLC about every 3 years, so that's why our software is a bit old.
Marty :D
Welcome to the Forum !
I'm going to be a little abrupt and cut you off at the beginning: FactoryTalk software is very sensitive to revision and patch differences. Attempting to mix incompatible platforms is a waste of everyone's time.
I very strongly recommend using a virtual machine and doing a clean installation of a single Coordinated Product Release.
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
515
Hello, I am trying to streamline an AOI that will get module/controller statuses from ethernet IO tree. Everythings fine, however, does anyone...
1,626
Hi, is there any way to export all contents of Block folder (OBs, FBs, DBs, etc) to a text file? I know it is possible to export symbol table, but...
1,275
I was looking at a Studio5000 PLC file as reference, and noticed the "standard" for this job used was using program tags for each program folder...
1,617
I'm looking for someone that may have a download file of TIA Portal V14 and 15. I have a customer that has 2 PLCs on is a 1212C with firmware 4.5...
3,463
