Older version of Siemens TIA portal to download?
dhracer3
Jun 2015
Asheville
I'm looking for someone that may have a download file of TIA Portal V14 and 15.
I have a customer that has 2 PLCs on is a 1212C with firmware 4.5 and the other is a 1214 with 4.5.1. and I have V13,15.1 and 17.
The project in the 1212 CPU was created in V14 and the 1214 is in V15.
I'm not able to upload either of them and get a backup.
What is the process of getting a backup of these plcs?
OK never mind.
Talked to Siemens and they said that this is no way of doing this without having the version of TIA portal.
Seems crazy to me.
But they were kind enough to send my a file exchange link with V14 and V15 downloads.
Hopefully this helps anyone else out with the same problem.
You can download them all from the Siemens site.
Status 12/2020 : Update 10
Here you will find the latest update to TIA Portal STEP 7 V14 SP1. All updates are cumulative, which includes all previous changes to older updates. For this reason, we only provide you with the latest update for download here.
If you require an older V14 SP1 update for special reasons, please contact technical support for this reason: Support Request
https://support.industry.siemens.co...1-and-wincc-v14-sp1?dti=0&pnid=14674&lc=en-WW
Good day all, i have a panelview plus 1000- 2711P-T10C4D1. The unit is dead and wont power up, i opened it up and tried to swop out the...
4,463
My memory is failing me. I seems to remember I could download which ever version of any Rockwell Automation software as long as they are covered...
2,511
***Never mind, made erroneous selection during setup*** Hello, I currently use studio 5000 Logix Designer version 31. I am trying to install...
2,410
I tried opening a file that is in version 20.03, but I have 20.01 installed. It attempted to open Studio5000 and prompted me with a message about...
8,152
I have two Panel View Plus HMI's on two different machines. The programs where wrote in a older version that doesn't allow conversion. All I have...
14,373
