studio 5000 logix designer, load an older version
qingrou
Jul 2018
Seattle
***Never mind, made erroneous selection during setup***
Hello,
I currently use studio 5000 Logix Designer version 31. I am trying to install and use version 24.01 and 30.01. The files are downloaded and extracted from the rock well site. They are copied over to a windows 10 VM; where I tried to run the setup applications. However, the setups failed with error message that a higher version is installed (assuming this is referring to version 31).
Has anyone encountered similar issues and/or know how I can resolve this?
Many thanks!!
Could be that FactoryTalk Linx 6.0 is causing the install failure.
Is there an option to select "Customize" install? Uncheck RSLinx 5.90
Then proceed with install...
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
241
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
144
Hey Guys, I am looking for a cr@cked version of Studio 5000 Logix Emulator V28 or Rslogix5000 V21, which will work with my current emulator...
299
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
485
