Intouch (Wonderware) vs. Factory Talk SE
I can not speak on InTouch. But as far as FT, let me say one thing before I get into it. I am a programmer, and not a graphically inclined one! So based off of functional use i have to say FT makes it very easy to tie things together. But I do have two negatives to share.
1st- if you are working on a major project PUT FACTORYTALK ON A VIRTUAL MACHINE OR ISLAND IT FROM THE INTERNET. I hope that was loud enough to hear because it always seems to happen during major projects or near due dates that windows decides to throw and update or patch and FT is not resilient to changes on the computer. See my recent post about a FT project I recently had to go to hell and back to recover.
2nd and this one could be because I spend more of my time in rs/studio and less in FT studio but aligning and centering images, text, shapes, or really anything is a colossal paint in the ——. And when I wrote this if anyone has another way of handling this let me know. But in order to get things centered you have to draw lines and make them half the size of the total size of the screen. I will post a photo of a (ugly) hmi but not that for everything there I had to use lines and calculations to find middle points then a lot of copy and paste to get it pretty.
Overall I’ll take the designing flaws for the functionality of the program. It is a very powerful tool! (And if anyone has tips for aligning let me know because although I don’t have to worry about hmi displays too much, I would like them to look a bit better)
Disregard the big black box at the top, I wanted to protect the clients information. But see that everyone of those boxes are their own item, making them all align properly required finding the central point in different areas with division and subtraction haha. Again if anyone has tips for me on that it would be greatly appreciated
The alignment tools in FTView Studio are fairly good. Yes, there are some with flashy features (Beijer) but you need to know what your options are first.
Most HMI designers will have similar tools, but the most important alignment tools in FTView Studio:
(1) the actual alignment tools: left/right edge align, top/bottom, middle horz/vert
(2) Group and ungroup (ctrl-G and ctrl-U)
(3) Pixel movement: select object, hold down shift, use the arrow keys
(4) Ctrl select-click: to add/remove items to a selection
(5) Object explorer and property panel; for exact size and XY changes
Use the (un)group as a temporary thing to help with alignment; not as a permanent state that you save the screen into.
Is that better than InTouch? ymmv
Hi Guys! Is there a way I can view a Factory Talk or Wonder ware In touch application on a phone and outside the plant? Response will be appreciated
1,714
139
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
156
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
409
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
183
