AB RSLOGIX DATA FILE
PERSPOLIS
Jun 2002
ontario
295
HI EXPERTS
ONE OF OUR MACHINE WHCH CONTROLLED BY PLC (5/03 PROCESSOR) ITS DATA FILE CONSIST OF FOR EXAMPLE C5 COUNTER, TIMER T4 ,INTEGER N7 ETC AND AT THE SAME TIME I NOTICED THAT N11, C15, T14 , ALSO ARE PART OF DATA FILE .
CAN SOMEBODY EXPLAIN WHAT IS GOING ON AS I HAVE NEVER SEEN SUCH A DATA FILE BEFORE.
MANY THANKS EXPERTS
You're probably familiar with the default data files that are used by SLC and MicroLogix controllers.
These data files cannot be deleted or assigned to different purposes: file 3 is always a Boolean file, file 4 is always a Timer file.
But for controllers that support expanded data tables (i.e. anything but the MicroLogix 1000) you can create more data tables, starting with File 9.
It is very common for a programmer to follow the theme set by the default data files; File 14 will be Timers, and File 15 will be Counters, for example.
It's not required to do so; You could have B14, or N15, whatever you wanted to define.
I stumbled onto this behavior the other day, then went looking for old forum posts with the assumption that "there is nothing new under the...
791
Hello All, I am working on converting a program written in RSLogix 500 to Connected Components Workbench. The MicroLogix to Micro800 converter...
1,219
Hi Guys! Does anyone know which version of RSLogix 500 i can insert ASCII DataFile? I'm using 10.0 version and i not found this DataFile, but...
1,460
Hello everyone. This might be a silly question for many of you here. I have created 2 separate ladders. One to control one part of the machine...
2,417
Hi all, Im trying to add some more elements to a Floating point data file without much success. Its already set up for F8:0 only. I would like to...
3,369
