Problem connecting from PC to ControlLogix PLC
SirTrollsalot
Jun 2014
Oregon
Hello all,
I am having a hard time connecting to my ControlLogix PLC.
I recently visited a plant and needed to set my wired network connection (IPv4) to "Obtain an IP address automatically."
Now that I have returned to my office, I need to connect to this ControlLogix PLC. I set my IP address to a static address that exactly matches my PLC. If you look at my attachment, you will see that my 'test_bench' driver no longer recognizes a controller, but now recognizes a computer.
I am out of ideas, and I followed my regular procedure in order to connect to the controller.
Any help will be appreciated. I am new to this stuff so anything helps.
Set your computer so that the first three groups match but the last one must be different than the target PLC, and different than anything else on the network if connected to more than one device.
Set your 'netmask' to 255.255.255.0
This will satisfy many situations.
If the computer's IP is the same as the one you just set then the computer IS your computer.
Open 'Communications' then 'Configure Drivers' - take a screen shot of that
The click on this last driver and click on 'Configure' - take a screen shot of that.
Post both
I believe you have configured an "Ethernet Devices" driver in RSLinx, and specified your PC as the address you want to talk to....
correct me if i'm wrong...
show us a picture of what you can see if you expand (click the + sign to the left) the Ethernet/IP driver called ABETHIP-1, Ethernet
well i finally got it to work. its hard to describe what i did in order to make this thing work. i can now talk to my controller and run a program with rslogix 5000.
i found that i had a 'LAN connection' and a 'VirtualBox Host-Only Network' in my network connections. I disabled the VirtualBox. I typed in a static IP address for the LAN connection that would go along with the PLC (10.59.8.xxx). When I looked at RSLinx i saw that my PLC appeared.
I was trying to use this virtualbox connection the whole time. i think that might've been there because of some kind of training i did? anyways, thanks for the help. it's now running.
thanks for the feedback....
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
5,121
Hello! We have one Omron NT11-SF121B-EV1 display and CP1L PLC. I want to connect this display to computer and upload graphics with NT-series...
2,355
Greetings i do have a new Siemens PLC station with 314 CPU 1DP i try to connect using the PC adaptor Cable USB A2 i do have the Error message...
2,251
Hi all Was wondering if you guys were able to help. I am onsite trying to program a 440C-CR30-22BBB Safety relay. Using the following pdf and...
4,417
Dear Members: I am new to Twincat System. I am working on a project. I have connected CX9020 with my laptop through ethernet cable. I was able to...
4,627
