Problem connecting Twincat with CX9020
Sohaib28
Aug 2015
Cottbus
31
Dear Members:
I am new to Twincat System. I am working on a project. I have connected CX9020 with my laptop through ethernet cable. I was able to find CX9020 through broadcast search and I was successful in connecting it. I also found my Inputs through scan devices. The TC LED light on my CX9020 was blue then and I was in config mode.But when I clicked Activate configuration my CX9020 was not connected with Twincat and there was a cross on CX9020. The LED light on CX9020 is green now. There is also written Timeout in the software. I am unable to find CX9020 in broadcast search. Now I cant get my system in the normal mode. Also the yellow Timeout is not going. Everytime I start my system and try to get connect with CX9020 Timeout appears.
Please tell me How can I remove this Timeout status.
The same problem I am also facing.
When I install HMI cabinet file it stop working.
My IP series same. 56.65.6.85 controller as well as my PC.
I found after installation of HMI I reset the controller in CX configuration tool it enable only visualization. It is not enable twincat.
If I disable and enable twincat as a device it working perfect but I can see visualization in my monitor.
Can any one help.
Thanks in advance.
Hi I been using a cx9020 and I have successfully been connected to the device but after a recent re-installation of Twincat don’t get connected...
2,588
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
5,063
Hello! We have one Omron NT11-SF121B-EV1 display and CP1L PLC. I want to connect this display to computer and upload graphics with NT-series...
2,342
Greetings i do have a new Siemens PLC station with 314 CPU 1DP i try to connect using the PC adaptor Cable USB A2 i do have the Error message...
2,239
Hi all Was wondering if you guys were able to help. I am onsite trying to program a 440C-CR30-22BBB Safety relay. Using the following pdf and...
4,385
