Message Instruction Path assignment - looking for ideas
Mark Whitt
Jan 2013
Columbus, OH
31
Thanks for taking the time to read about my dilemma!
I'm in the process of writing a Test Program that needs to be able to test many different kinds of devices from a ControlLogix Processor over Ethernet/IP, and I'd like to be able to assign an IP address to the device under test and have it come in on one of the Generic Ethernet Modules that I’ve already set up with a pre-existing IP Address.
The problem I'm running into that there will be a lot of different kinds of Generic Modules, each with their own I/O Assembly instances and data sizes. But I’ll only be testing a few devices at a time, so I don’t really want to set up a bunch of message instructions for each Generic Module because that would translate into a huge program very quickly.
Instead, I'd like to use a single Message Instruction and update the connection path with the IP address already stored in the desired Generic Module as needed so that the message goes out to the device that I'm currently testing.
But I'm not seeing a way to grab the IP address out of the Generic Modules from the program so I can plug them into the Message Instruction path. It seems like this should be possible since you can select the module from the Path Browse button.
My first thought was the GSV/SSV instructions. But so far I'm not seeing how to make them work for this purpose.
I guess I could keep a separate list of the IP addresses and plug them in as needed. But I don't like taking the risk of a typo causing a problem, or having the list updated later (maybe by someone else that doesn't understand the system) and having everything get out of sync. So, I'd prefer to get the IP address directly from the module I'm trying to use.
But maybe my thinking is too narrow. Maybe there is a different way to do the same thing?
If someone could point the way, it would save me coding up tons of redundant message instructions along with the code it would take to decide which ones to use.
Thanks again for your time!
Mark
What's the easiest way to monitor a CIP data table read or write instruction. I'm reading and writing from a Compact logix to a micro 820, over...
1,535
Studio5000, V31 I'm Messaging a MassFlow Meter, specifically to pull the Engineering Units (units of measure) for 6 instances. Basically, do I...
1,246
Good day I would be so glad if anyone can assist me. I have a message instruction and i am sending data between 2 PLC's. The Message...
3,308
I have been working on creating a subroutine for my company to send an email from my controller to our email server and had been successful in...
2,466
Hello, I'm trying to read a parameter from a Power Flex 525 drive to monitor output current in order to detect a jam condition in carousel filler...
3,713
