Can 5069-L33xx local rack be expanded?
skyfox
Nov 2006
CA
279
1768-L43 Local rack was expandable in to a 2nd Rack via an expansion cable. For an example;
PS ENET CPU I/O I/O I/O I/O [Expansion Cable] - Main Local Rack
PS I/O I/O I/O .... [END CAP] - Local Rack Expansion
Can the Same be done with 5069-L330xx series PLC's? I couldn't find any info that said it could or couldn't be done.
Thanks-
Don't think you can. At least if you put it into IAB and try to configure a second bank it won't let you like it lets 1769/1768 processors
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
132
Hi everyone, Kind of new at this, so we recently upgraded our 1769-l32e to the newer 5069-L320erm, i converted the file over and Verify the...
451
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
580
Hi all, have a project which requires reading a weigh head weight over ASCII. Never really touched ascii so struggling a bit. The weigh head is in...
1,272
Hello, I have a laying out a system that will have a CompactLogix rack and I had a question on the power for the inputs and outputs. I was...
396
