5069-FPD for 5069-OB16 or LA Power
kloc5
Apr 2014
St Louis
25
Hello,
I have a laying out a system that will have a CompactLogix rack and I had a question on the power for the inputs and outputs. I was planning the rack as follows:
* PLC
* 5069-IB16
* 5069-IB16
* 5069-FPD
* 5069-OB16
I was planning to run 24VDC to the SA Power connection on the PLC to provide power for inputs to the two 5069-IB16 cards. The purpose of the FPD was to connect 24VDC that runs through the safety contactors so that power to the outputs would be killed on an e-stop. However, I noticed that the 5069-OB16 has a connection for LA power and now I'm not so sure. Could I just connect the 24VDC that goes through the estop chain to the LA connection on the 5069-OB16 and forgo the 5069-FPD?
If I did this, then I guess any downstream cards would then still have the original non-estopped power and I would just have to connect the estopped power to the LA Power connection of any output card that I want killed by an estop.
Thanks,
Keith
Hey all, It's my first time programming a compact guardlogix and first time using a 5069-fpd to add a 120V ac input card at the end of the rack...
780
Logix Designer 5000 V33 pro I have a 5069 backplane in the hardware config with 13 slots. In 3 of those slots, I need to have a 5069-FPD. When I...
1,919
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
110
Hi everyone, Kind of new at this, so we recently upgraded our 1769-l32e to the newer 5069-L320erm, i converted the file over and Verify the...
401
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
547
