A new S7-1200 PCB
segment
Oct 2016
Netherlands
I ordered one about a week ago and it's a none stock item so it'll probably take 2-3 more weeks to get to me. I would be happy to take it apart to take pictures for you but you would have to translate about 2000 dutch symbols in an Omron program. The translation would have to make sense programmatically as online translators don't make any sense. I'm not kidding.
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
253
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
82
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
129
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
179
