Wondering how to maintain , backup , restore , etc. DeviceNet till I replace in 2018
Aug 2016
Virginia
343
Good Morning ,
I think I have upper management convinced to begin replacing our SLC 500 PLC's . It is incredible the increase in price on SLC 500 components . I have struggled for several years , truly understanding how DeviceNet works , how to maintain it , back it up , and restoring it . I was thinking of purchasing a few 8 channel Analog modules but the price jumped up to &2,700 dollars each.
I am not sure what DeviceNet data , scan lists , etc. we have backed up on our machines. What method do you folks suggest using to backup all our DeviceNet systems , and how do we restore if something happens. Do you go thru the Serial port to capture this DeviceNet data. I guess you use Networx / DeviceNet to do everything , correct ?
Thanks so much for advice , like always.
I don't think you can bridge to the Device net from serial port on 500's
you will need a comp of RXlogix Networks for device net and a adaptor to read write the to the network
then scan the network then save it then copy the scanned module configuration and save it.
Hey all, I've recently been asked to help spec some SCADAPack controllers for a project. I'm specifically being asked if the E series...
8,025
Hi I just were sitting in my desk and was wondering if by any chance any of you worked for Eaton in Aurora or Berea in Ohio. Aurora was full of...
1,632
Wondering how to "defeat" the left hand most timer in Logixpro I/O simulator Wondering if any one can help answer the attached two questions...
2,208
I'm working with SLC 500 Data File. I have a few numbers like 8.313452e+07 . I forget , how do you convert these numbers . Thanks so much.
2,506
Hi guys! Newbie question or you. I'm just finishing up a diploma in Industrial Automation. But I am job hunting and I'd some clarification. We...
2,167
