Instrument air deyer program
shkoko2000
May 2011
cairo
296
Dear all,
Hope you are well,
Anyone have dryer micrologix program as i have jemaco dryer operated with microcontroller and i need to convert it to micrologix plc. So i need any guide for me
i have worked on a jemaco air dryer and from memory it had its own SBC embedded controller.
are you saying your machine has a micrologix?
or has its OEM controller failed and you want to retrofit with a Micrologix ?
sorry i do not have a program for one.
The problem i faced that how to calculate the dryer load. All existing sensors are inlet temp, inlet pressure and outlet pressure. I need to know the equation for load calculation and also humidity.
Given what you are said here, I don't think we can help you. You will have to find someone who is able to perform the work.
I recommend you approach the oem for a replacement
Control system for that model. Trying to recreate from start
Is a lot of development time for little gain.
i have many dryers in our plastics process. I see no way you can calculate Humidity simply based on Temperature and pressures?
all of ours have humidity which gets us to dewpoint
On site we have Yokogawa EJA110E differential pressure transmitter connected to process air line. I'm not sure if this can be used to measure air...
4,414
Hi all, Looking for a temperature sensing solution for determining ambient temperature in the frigid Canadian winters. Discrete outputs are fine...
1,499
I was tasked with putting together equipment for a mobile temperature monitoring system for our oil rail cars. Apparently, the crew that unloads...
835
Hello, I have a question regarding instrument cable. I know that for 4-20ma transmitters twisted pair cable should be used with the screen...
2,251
Hello, We have a 6es7 32101BL00-0AA0 DI card. There is a level switch to be added from an E&H FMR62. Our client is of the opinion that as the...
1,244
