Micromaster420 control via modbus from Modicon M241
RodriWilliams
Dec 2015
swansea
Hi, I'm trying to start, stop and change frequency of a MM420 from a Modicon M241 Plc via SL2 485.
I've looked on the net and cant find much. But what I have found I cant get my head around sending the commands from the plc. Would anyone have an example so I can see how it works.
any help would be appreciated
Rod
Thank you JRW,
Is there a better way to this? would CANBUS be better.
Would any one have an example of m241 to mm420 via CANBUS?
many thanks
Rod
****update**** it looks like I need to consider using profibus for this now as my M241 doesn't have CANBUS
M241 can only be profibus slave with communication card.
And micromaster can only be slave too (I think so)
Two profibus slaves don't work together.
Only suitable way would be connect with IO or using modbus master -> profibus converter between
PLC and driver (and it will not be cheap or easy)
some M241 can have canopen o_O
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
116
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
88
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
217
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
420
Hello Dear users, I am writing about a problem that has been bothering me for a few days, i.e. I am trying to establish remote access to the Allen...
88
