Unity Pro - Possible to alias variables to an array?
FNC
May 2010
NJ
84
I am using Unity Pro XL 4.1 and have a question.
I am used to programming on Allen Bradley and this was possible in ControlLogix.
I have 16 boolean tags. I now want to create an array of 16 booleans and then map each one to each of the 16 tags.
Is this possible or do I need to create a new tag of type Boolean Array [16]?
Thanks.
FC
the easiest way is to set an address for the array and then set the corresponding address for each of the individual tags
Boolean Array [16] %M100
Bool1 %M100
Bool2 %M101
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
191
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
415
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
741
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,958
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
782
