Testing the HMI
bradyundt
Apr 2005
PLC: Simatic S7-300 CPU315-2 DP
HMI: Redlion G306
The PLC guy has already finished programming the unit but the HMI wasn't connected to the PLC because it wasn't shipped at that time. Now though the HMI has arrived, the PLC guy won't be coming until 27th.
I was wondering if there was a simple way to make sure the HMI is working. For the last couple of days i was fooling around with the software that came along with the HMI (crimson 2.0) but have gone no where.
Can someone tell me the cabling details between the RJ45 (RS485 port) of HMI and the RS485 (MPI adapter)of the PLC.
All i am trying to do is create a tag, map it to a register on PLC and then modify that register.
If any configuration is required with the PLC software then i will have to forget the whole idea because even though i sat with the guy for almost a week, i couldn't make any sense of the software he was using.
any ideas...
hi all ! does any one know how to test the Ladder Logic developed using RS LOGIX 500 & HMI using Panel Builder.
5,693
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
103
Hi all, I have a AC current transducer that I want to bench test to ensure I am getting a 4-20mA output. I am using a AE001 unit. It is very...
119
Hi Guys, Can ControlLogix with Modsim32 for Modbus Server Testing? I have ControlLogix via Anybus Modbus TCP and I need to Test the...
313
Hello all, looking for ideas on getting some basic training done, I need to practice on maintenance timers and bypass switches (with a Factory...
1,316
